LAMPSguy
I have searched - nothing found, new post
I am using the current revision 1
12-04 Step 3 "enlarge lower fwd systems hole as shown in figure 1"
Figure 1 calls for 7/16" - SB437-4 or 1/2" - SB500-6 yet the callouts in figure 2 show SB375-4 (requires 3/8" hole).
Since the revision changed the callouts on this very page, what goes there? Is the callout correct(SB375-4) or is the Figure 1 correct and should I be placing SB437-4 here?
**edit** I added up the total required bushings based on what the plans call for and none of the numbers match up with the quantity shipped/nor the quantity listed in the inventory. I was hoping to use that as a guide for which bushings went where. I am not worried about the hardware, I just want to drill the correct holes!
