What tool do you use FIRST to smooth out the bumps that are on the edge of all pre-punched skins and many other parts?
1. Vixen file
2. Regular metal file
3. Small Scotch-Brite wheel in die grinder
4. 6-inch diameter Scotch-Brite Wheel
5. Scotch-Brite surface conditioning discs
6. V-blade deburring tool
7. Hooked blade debarring tool
8. Sanding block
9. Other
1. Vixen file
8. Sanding block
9. Other
