Been using regular smoke oil from Blazing Oil at the SUS airport. I have one of Marvin's Smoke System Helper systems in my -4 and http://www.smoke-system-helper.com/works flawlessly. Had a recent discussion with him about oil. For small topoffs he said it would be OK to use new, clean Automatic transmission fluid, just saw a case of it at Sam's cheap. He aslo said I could mix it with my smoke oil if I just needed a top off.
Anybody have any thoughts on this or been using ATF?
Oly
PS- you guys need to call him if you want an I expensive quality system that he can custom make to your specs. He did mine perfectly, go to the link below now. You know you want one!
Oly
