bobmarkert
I?m ashamed to admit I?m a dribbler??.
When I turn my smoke system off it shuts off immediately then 10-30 seconds later the lines must drain (running two injectors that are joined together at the firewall) and I puff smoke for 3-5 seconds. The check valves don?t help. Buck Roteman of Wild Horse Aviation airshows uses a solenoid on his Pitts and it works perfect so I installed two of them on my system. I have some oil leakage at the pipe fittings that go into the solenoids. Can someone recommend a good sealant? Fuel lube (Ez Turn) advertises it?s a sealant, as does locktite 505. I?m not a fan of Teflon tape and would NEVER use it in a fuel system and prefer not to use it in my smoke system except as a last resort. Any suggestions are greatly appreciated.
![](/proxy.php?image=https%3A%2F%2Fi821.photobucket.com%2Falbums%2Fzz136%2Fbobmarkert%2Fselenoid_zpswxbtcrez.jpeg&hash=9e3e5cb695e3ec1e3450037a135a01d0)
![](/proxy.php?image=https%3A%2F%2Fi821.photobucket.com%2Falbums%2Fzz136%2Fbobmarkert%2Fez%2520turn_zpsobszbrhm.jpeg&hash=12091feae639308f8bc18964c430c4f9)
![](/proxy.php?image=https%3A%2F%2Fi821.photobucket.com%2Falbums%2Fzz136%2Fbobmarkert%2Floctite_zpsvtbqhiuz.jpeg&hash=21bc07076770bfabe15f69990241cafb)
