Smartphone and the RV-12
mcems
Has anybody found a good way to feed the cell phone(smartphone) thought the headsets on the RV 12 .
I have tried many different ways. Right now I have 2 different brand head sets with the cell phone adapters with cables. They both work just fine when your setting in the cockpit on the ground not running the Rotax.
As soon as you fire up the Rotax it stops working (person on the other end says is very weak and broken then drops off.
Thought about getting one of the expensive blue tooth headsets ,but not sure that will fix it.
Love using the Apps on the Smartphone .Would love to be able to talk on it too.
Any ideas???
Brad
I tried the same thing with the Bluetooth in my Zulu 2 and had the same result. Engine at idle I was barely readable.
