LifeofReiley
I can't seem to find the thread. Who was it that located these? I need them for #8 screws, the ones I saw here were just a tad bigger than the head of the screw. Help...
One way to do this is to get Tinnermans for a #6 and drill them for #8s
Jim Berry
RV-10
I used these types. Not from this supplier, but if you Google "#8 flush countersunk washers" you will get a lot of options.
www.clipsandfasteners.com/No_8_Flush_Washer_Nickel_On_Brass_p/a604.htm
One thing to be aware of. Most are not the same countersink angle. 100? vs 120???
Anyway, I would take a washer and then put the screw in it and tap it so that the washer reformed to the screw.
Hope this helps.
Genuine Aircraft Hardware (in list of advertisers) has all the sizes and very helpful in locating what you need. That is where I found mine.
I have 'em in #8. Dang near impossible to pick up if you drop 'em.
Carry on!
Mark
These are from Wicks.
Was wondering? I have tried to drill the washers with little success, how do you
hold the washers while drilling without scratching them?
