Do it all of the time. I takes a lot of pedal force, but it's very effective. Sometimes it's the only way to slow down and get down.
Compared to other aircraft (Cessnas and Pipers) they don't slip very well. It takes considerable rudder force and doesn't produce a significant increased rate of descent. For example, power at idle, full flaps and 70KIAS my rate of descent is about 5-600 FPM. In a full slip I see it increase to 8 or 900 FPM. In a 172 it's pretty easy to get it over 1500 FPM. I don't believe there is enough surface area in the slip to produce high amounts of drag. Still, I slip often and have not noticed any airspeed or altitude errors. In order to really get the plane to increase the rate of descent you have to slow it to about 60KIAS. I have not done any "cross-control" or "slip" stalls, so I am not comfortable slipping below 60. I have done an "approach to a stall" at altitude in a slip configuration and the stall buffet seemed to be pronounced. I have yet to do a full stall in the slip and am curious how the plane will react. I suspect it will self-recover, but I don't know for sure. I also would like to test the extended slip effect on fuel pickup as Pierre comment on. For now I use my high wing fuel tank in the traffic pattern.
I don't know where you heard that one. You can fly these things sideways if you get your airspeed low enough to deflect the rudder enough.
slips, yup they are hard to do in an RV.
pull power off, the prop goes flat automatically.
but what works the best is S turns, now sometimes I slip with right rudder, which is hard if speed is around 80kts, and left aileron and put it into a side slip, than I'll pull hard right aileron with no rudder and repeat all the way down, this is on a final into the left runway, helps with traffic on the right runway, my airport has two runways. Now if I can do a base to final and my speed is to much I run 80kts with the c/s no problem, what I do is make a nice hard base to final, like 60degrees and it will lower my speed to 70kts right now, way cool, and don't forget, full flaps on decent from the downwind. this works great for me, I can't speak for those with a set prop. I can't imagine that one.
Just to let you know, I put in about 350hrs a year so I'm a little more experienced than most.
Hours are no indicator of skill, judgment, and experience - they just happen to be the only data point the insurance companies have. But your posts leave little doubt about your skills.![]()
what?
Now let me put this out about slips I love them, in the kitfox they are a non event, they work very well. In an RV, I don't care which one you have, they are not that affective. That's comparing to the kitfox anyway. I generally don't use them, I find the s turn more effective, or a steep turn on base to final. I'm done.
Why censor it? It was that persons opinion. I read it to say it left little doubt of allbee's technique. It did not say he had no technique or skills. You have your opinion, everyone else is entitled to theirs. That doesn't mean people should be censored just because you don't like what they have to say.
I read in another post here that RV-9s do not slip very well. Can someone expand on this point for me? What are people's experiences with side and forward slips in the 9?
Tom
Re an earlier post, full flaps, 70 knots and 600 fpm, yields a glide ratio of almost 12:1. This does not seem possible with full flaps. ....
I am not sure what the upper speed limit is for slipping the RV9 or even if there is one. Anyone got any ideas?
Flaps up or down?I am not sure what the upper speed limit is for slipping the RV9 or even if there is one. Anyone got any ideas?
Va would be the "upper limit".
