alpinelakespilot2000
See edit at end of message...
If anyone can help, I'd appreciate it. It's really hard to visualize how all the parts of the slider canopy mechanism will fit together until you actually do it...
Does anyone know of where there might be an specific indication re: where the aft end of canopy tracks should rest?
I can't find any reference on the drawings. Currently the fwd end of my tracks are resting up against the rollbar, and my rollbar is (as best I can measure) exactly 2-5/8" aft of the center section bulkhead rivet per View C-C, Dwg 42. The length of my canopy track is the 24-13/16" per Dwg 41. One would think this would give me the proper aft location. However, when visually compared to the scaled drawings of the plans, the aft end of my slider track seems to be about 1/8" farther aft than shown in detail B of dwg 42. (I'm basing this 1/8" estimate on the locations of those rivets that hold the F-757-s plate down on the top of the F705 bulkhead.) Re-positioning the aft screw that holds the canopy track to the canopy deck is no big deal, if necessary, but I suspect there is a specific place the track has to end since the rear pin mount will need to be mounted in exactly the right fore-aft position to hold the canopy down in the back.
I realize I may be worrying about nothing, and maybe it doesn't really matter that much, but I definitely would like to be as sure as possible. Thanks for any help.
Edit-I mis-typed the above post. After checking it appears that the aft end of my canopy TRACK is fine, it is the aft canopy DECK that I must have mis-positioned slightly forward. This seems kind of strange since my forward canopy deck fit quite well once the subpanel when on, but maybe I trimmed that aft edge of the fwd canopy deck a little to make it fit. Can't remember. Hopefully having the aft canopy deck about 3/32-1/8" fwd won't cause any issues but I don't think it will. Still, does everyone else's canopy track end up positioned about the same as the scaled drawings seem to show? Anything I should be watching out for given this? Thanks again
