papamike
Hey everybody. I read an older post from 2-3 years ago where somebody had a perfect windshield bow. Mine is very nearly so, but I want to make sure...
Is it OK to have a very slight preload pulling the frame into position to mount it? Not sure it's worth the work to bend it for the small amount of adjustment that may be needed.
I also have a little bit of "toe-in" on the left side. Does that support brace have to be parallel, or can I get away with that difference as long as the position is correct and the bar is square?
![011416019.jpg](/proxy.php?image=http%3A%2F%2Fsmilinpete.com%2Fwp%2Fwp-content%2Fuploads%2F2016%2F01%2F011416019.jpg&hash=4048aaa3cb30e5426614938d7d9e1233)
