Hey everyone. I'm fighting with the slider canopy and am starting to get really frustrated. Here's the situation. Right from the beginning my frame and canopy fit terribly. to position the frame for the "best fit" I was instructed by Vans to split the difference of having gaps in the front bow and the aft portion of the spine. This left me after the big cut and trimming with a 1/4 inch gap at the front bow and a few spacers on the aft of the spine. So I had to make a spacer for the front bow of the canopy frame. I know, less than ideal. I have now trimmed the windscreen and am at the point where the plans show a 3/8" height difference between the center of the frame front bow to the top of the roll bar. The issue is that with a 1/4" spacer between the canopy and the bow the top of the canopy is much higher than the top of the windscreen. So I guess my question is should I knock off as much of the leg where the rollers attach to bring the transition between the screen and the canopy to something acceptable? Or do I shim the windscreen to match the canopy? How critical is that 3/8" difference or is that just a nominal value assuming no spacers for a smooth transition? If I cut off 1/4" from the roller legs this will make the top of the roll bar to center of the frame height difference 1/8".
Hope this all made sense and I appreciate your responses.
Trevor
Trevor
