I must be missing something here. RV-7 slider roll bar, I measured off of the pre punched hole 2-5/8" aft as per the measurements on the plans dwg 42 section c-c. go to drill off the roll bar I make a quick mark on the bottom of the bar just to confirm I'll be able to retain my edge distance (must be learning a few things along the way). When I check I find that to get minimum edge distance on the forward bolt I would need to move the roll bar forward nearly 1/4"! I checked all the measurements for the pilot holes, I dont have the drawings with me but I recall 1/2" aft of an indicated rivet and 7/8" inboard from the skin. Am I missing something?
Thanks for any and all insight.
