When trimming the canopy, I extended the line at the bottom of the square tube forward and trimmed. This has left only about 1/4" overlap on the sheet metal which overlaps the lower rollbar on each side. At the same time, there is as much as 1/2" gap between the lower edge of the windscreen and the far lower side of the glareshield area forward of the rollbar.
I'm having a hard time seeing how this all comes together. As I trim and radius the front corners of the windscreen, is this all going to come together?
How best to draw the radius at the front corners of the windscreen for best fit?
Could someone post some images of these areas in progress of build.
