Hello Gentlemens,
one Question: How much have you done the Slider Frame Rear Bow (in the Pin Area) bend "inboard" without the Canopy Bubble?
Gays tell me the Frame (rear) goes a little bit "outbound" when you have mounted- riveted the canopy bubble...
Have you the same Situation?
What is the best Dimension/Position from the Rear Frame without the Bubble.
Or ist it ok when the Frame (when fitting is finished) moves exactly with the Pins in the Polyamid BLocks? (without Bubble)
Thanks for Help
nice Greetings from Austria
Manfred
Thanks for Help
Manfred
