I'm having a difficult time figuring out when and how to adjust the height of my slider frame. The front bow is sitting 13/16" above the roll bar at top/center (7/16" too high per the drawings). It isn't clear to me when to cut the bottom of the bow for height (where the roller assemblies insert). I'm thinking I need to do it now, after I have adjusted the square side tubes to match the fuse (which didn't take much at all, BTW). But I don't want to make this cut prematurely, so I thought I would ask. Am I on the right track?
And I'm really not sure how to adjust the height on the rear bow. Right now the top/center of the rear bow sits 1/32" above the F-7112 aft top skin. The instructions say this bow should sit BELOW the aft top skin by 1/16" to 1/8", and to adjust accordingly so it does.
I've spent a fair amount of time perusing previous threads, but I haven't found anything that really addresses this. Any help/suggestions/words of wisdom would be appreciated.
Thanks.
Thanks.
