Hi,
I am fitting the canopy to the canopy frame and so far the canopy does not follow the curve of the frame down the central fwd aft bar of the frame. This is the piece of the frame that goes from the latch, back to the slide block rail area.
The canopy is making good contact with the frame for the initial curve from the latch, over the hump then a gap develops between the 2 until close to the back of the frame. It takes a fair amount of pressure to get it down and in contact with the frame.
Is this gap an issue?
Should I build up a spacer?
Any other ideas?
I plan on using sikaflex.
Thanks.
Any other ideas?
Thanks.
