I'm making good progress on my slider canopy (so far no cracks), and started looking ahead at the anchor blocks. When I put the brackets in place over the longeron as per the plans, the probe(?) from the canopy frame points inward so much that it actually hits the inside of the bracket. The right side is worse than the left, but they both seem to point inward more than they should. Has anyone else had this problem, and is there any reason I can't just gently bend them out slightly for a better fit? Of course, my main concern is the possibility of braking one off.
