Slick or easy way??????
PerfTech
Anybody have an Easy way to verify the oil temperature or check the Vans gauge and sender for accuracy? Thanks, Allan :rolleyes:
My Van's oil temp gauge ran approx 20 deg low even though it "tested" ok in boiling water. When I upgraded to an EI gauge my usual 160 oil temp came up to 180. I believe it was due to the actual temp probe being totally shrouded by the probe adapter, the EI temp probe has no such adapter.
