chuckwn
Ignition System Failures:
The 1535 hour life of my RV-8 has now seen two ignition failures. Both of these were failures of Slick Magnetos purchased brand new when the plane was constructed. Note that my RV has been equipped with one Lightspeed ignition and one Slick magneto for the last 1400 hours.
The first failure occurred at around 1000 hours in the form of a magneto coil failure. Of course one discovers this during a magneto check and away from one's home airport. This was resolved by installing the mag I had removed for the Lightspeed installation and replacing the failed magneto.
The next failure was the a condenser failure. This happened on the magneto that had only 500 hours since new. I was able to repair this by stealing the condenser from the mag with the dead coil.
At this point, I was so distrustful of Slick mags that I flew around with a spare slick mag with the proper gear bolted on. I also carried a magneto timer and appropriate tools for a field repair.
One only has to look at the parts prices for Slick mag parts to see that the failure of a coil ($278) is nearly half the price of a new magneto and a condenser at $108 is outrageous. Further research reveals that Bendix magneto parts are priced at roughly 1/3 of Slick prices (Coil $98, Condenser $21).
After more discussion, I decided to switch to a Bendix magneto for three reasons.
1) Cheaper parts
2) More reliable (Hopefully)
3) Hotter Spark
Bendix mag's can be obtained from aircraft savage yards for very reasonable prices. One nifty option I also employed is conversion to an automotive ignition harness and plugs using guidance from G3i's website:
Magneto Ignition Harness Conversion to 8.5mm Super Conductor Automotive Spark Plug Ignition Wires:
Bendix Series 4 & 6cyl. Magnetos
Slick Series 4 & 6cyl. Magnetos
1) Cheaper parts
3) Hotter Spark
