slick mag
lawrence
Patron
greetings all: my slick mag is marked as left turning.from whose view point? the pilot sitting in left seat? or mechanic looking at the gear end of mag? thanks
LH Mag
I believe all the mags for a standard rotation engine should be marked LH. If the engine was an LIO-XXX like on later Comanches with contra-rotating engines, then you would need RH mags.
