A little confused by the documentation I’ve been able to find for Slick 4370 and 4371 on a Lycoming O320. Engine has been modified to produce 160 hp with 8.5:1 compression. Left mag has impulse coupling. Data plate says lag is 20 deg on that magneto. Question: At what point on flywheel rotation should points open on this magneto to be properly set?
