Slick 4371 Magneto part numbers
jeffsvan
Looking through the parts catalog I am not sure I am seeing these numbers.
Slick 4371 Mag.
Need fiber washer, star lock washer, and nut where the lead attaches.
Need a part# so I can order.
thanks.
Slick parts
Unfortunately, I think they only come as an assembly with the capacitor. I was able to find phenolic washers that are almost identical and the nut and washer is something you should be able to find locally. I can send you one of the phenolic washers if it will help.
If you have size of the nut, or part # for the washer you did buy I would appreciate it.
I am trying to get 3 of each.
You could call Aircraft Magneto Service in Stevensville, Montana.
They go through about 12 or 13 hundred Slicks a year, so I'm sure they have a few spare parts.
For those who could use this information:
Was able to get the part #'s from Aircraft Magneto Service in Stevensville, Montana. They do not sell hardware, but all of this is in stock at Spruce.
