SL40 interchangeable?
jferraro17
Opulence, I has it...
Is there anything from installation to installation that would keep one SL40 from working in another's rack? IOW, pull a working SL40 out, and plug in the "test" unit, it should fire right up, correct?
J
J
Swap away Joe, no problem.
I loaned my SL 40 to a buddy while his was getting worked on, it just slid in, and was good to go.
J
Correct, you should be able to swap them out. Settings may be different, but it should work. Good luck...we'll see how good of a job UPS did!
Stein
