SL30 connector fastners
brian257
Just got a used SL30 with the tray, but no DB connectors. I have connectors I can use, but based on the size of the screw holes they use a bushing type screw so they can float a bit and align with the radio connector. Does anyone have a picture of what is used or a part number or source on the fastners? The only thing I can find is the complete kit with the tray and connectors for a good hunk of money.
The dsub connectors don't float. The antenna connectors do. Any d-sub will work, with a screw and a nut, but you can get connectors with nuts in the connector so you can just screw it on.
Thanks. Had that confirmed by a local avionics shop also. They look like they float since the holes in the tray are so big, but on closer look they are countersunk slightly. Just the BNC connectors float.
