Junglepilot
Just got everything wired and did a smoke test tonight.
First Garmin SL30. TX & RX fine over headets front & back with wife using a King handset.
Then turned on Dynon Skyview. Powered up fine. Configured fine. GPS worked. etc etc.
Then I looked over at the SL30 and I saw a message "COMM FAILURE". Hmm.
I turned off the Dynon, and almost instantly the Comm Failure message left and frequencies were displaying as before & back up. Turned Dynon back on and a few minutes later SL30 again says COMM FAILURE. HMM.
Thought it might be a power issue. Charged battery to 12.5v. However same results exactly with full battery.
Someone suggested on an older thread that maybe this is an issue with the SR232 serial connection. This makes some sense as that is the only connection between the two units. But that's a pretty basic connection. Double checked the schematic from my avionics guy. RX to RX, TX to TX, and AF ground connected. Unless I'm missing something.
Any ideas? Things to check? I'm almost certain it will be a simple solution. Believe the Garmin is fine. I think the Dynon connection is the issue.
