Jamie
Does anyone know what happens if you have an external VOR/LOC/GS indicator (i.e. MD-200-306) connected to an SL-30, but you also have the SL-30 connected to a Dynon via the serial line? Will the Dynon still display the HSI fine? I'm assuming the Dynon gets the OBS info from the SL-30, which is getting it from the MD-200-306? So you rotate the OBS knob on the MD-200-306 and you see the OBS on the Dynon changing as well?
Just playing with IFR panel upgrade options.
