jaybhansen
Member
I have had the re-boot code, but forgot to write it down. Anyone have it?
How to Reboot the Display
Press and hold buttons 1, 2 and 5 simultaneously to instantly reboot the system. This may be helpful if you need to cycle power after changing certain settings and for general troubleshooting.
SkyView Classic Pilot’s User Guide – Revision AB 3-7
Thanks. That's going on my checklistAll the combos
Button 1: Hold to shut down or hold to turn on Skyview
Buttons 1,2,5: Press all together to reboot Skyview
Buttons 2,7: Press together for Screenshot
Buttons 7,8: Hold to enter setup menu
Just the other day, I was flying a Dynon Skyview, and while descending, it completely froze up! Airspeed, altitude, attitude. .everything froze! I was able to swap it to another display, but is this common on Dynon? Does this ever happen to Garmin? If I only had one screen, and was in IMC..this could be a disaster.
EXACTLY my philosophy.If you fly in IMC with only one screen, no backups, then yes, you are rolling the dice. With whatever brand efis you might have.
FWIW; in 8yrs and over 900hrs of flying I have never had this happen with my dual SkyView system. But failures happen to all systems, no brand is immune. That is why a well designed system with adequate redundancy is critical in our airplanes. YMMV
What software version are you running? 16.0 has just been released, which fixed a bug that could sometime cause problems booting or freezing with certain USB sticks.
What brand of usb sticks were causing the freezing up?
