Skyview + GRT CS-02
kpaulsen
Member
I would like to use the GRT CS-02 to measure current with my Skyview EMS220. Has anyone been able to characterize this and create a workable sensor definition for the sensor configuration file?
Just curious, why the -02?
Dynon supports the CS-01, which I am using on my 120 --- why are you going with the -02?
Because I happen to have one laying around and would rather not purchase a CS-01 if I don't have to. This is for my standby ALT which is only 20amps so CS-02 should be adequate.
Have you had any luck solving this? I have a CS-02 on my secondary alternator as well, and would like to read it!
Nothing yet I've wired it up and selected the configuration for the CS-01 in the sensor setup but Skyview doesn't even recognize the CS-02. If you have any hints would appreciate any input.
