Building a tip-up -9A. Was able to fasten the panel to the sub structure this evening for the first time and got confused about something. Of course I had to take a minute to sit in the left seat. As I was imagining a 10 inch Skyview screen in front of me I realized that directly behind where the screen would be mounted is the rib that provides the structure that the panel mounts to. That means there is no depth available behind the panel to accommodate the Skyview unit.
For other -9A tip-up builders - what am I missing here? How does a 10" SV unit get installed directly in front of the left (or right) seat? If it needs to be offset it would seem a significant offset would be required. Comments appreciated.
- Lars
- Lars
