Skyview Conversion, Figure 2, page 42D-20
FredC
Member
I am doing a Skyview Conversion, Step 5 and Figure 2 on page 42D-20 were initially very confusing to me. Here are some notes I made after figuring this out.
This part of the conversion requires wiring harnesses WH-00026 and WH-00026 Rev-1 Kit (also known as Fix-1) supplied in the Skyview Conversion Avionics Kit.
On the left side of Figure 2, I labeled RZ942 and RZ943 as wires in the WH-00026 Rev-1 Kit. On the right side of Figure 2, I labeled RZ194 as the Pilot Headset Harness, and RZ195 as the Co-Pilot Headset Harness. Also on the right side, RZ944 is in the WH-00026 Rev-1 Kit.
I then cut off the male pins from the Pilot and Co-Pilot Headset Harnesses and spliced on the WH-00026 Rev-1 wires as shown in Figure 2.
At the top of Figure 2, I labeled the "OPTIONS" and "AUTOPILOT" connectors with "REAR VIEW/PIN INSERTION SIDE."
I then removed the backshells from the OPTIONS and AUTOPILOT connectors, inserted the pins from RZ941, RZ942, RZ943, RZ944, and reinstalled the backshells.
