If anybody is having trouble figuring out how to install the Skyview ADAHRS modules, may I present my solution.....
It's fitted just ahead of the F1007 bulkhead. You need 2 off outside flanges and one central without the front extension. Make a left and right tray. Longer flange is in the centre, wider at the front. Takes a little bit of head-scratching to get the angles right but otherwise pretty simple. Offer up one side, get it all square and match drill, then match up the second side and the stiffener on the bench. Fix to the tailcone stiffeners using LP4-3. Total weight is 1.5lb including modules. Load tested to 9lb without issue.
Enjoy!
Enjoy!
