Skybolt spacing on RV-14A upper cowl
stigaro
I've noticed that spacing of SkyBolts varies across different builds. It looks like SkyBolt recommends 3.5" spacing and this is what the flanges work out to without cutting. At this spacing, I can get between 14-16 flanges across the upper cowl depending on how close to the lower cowl I go (I'm keeping the hinge on the lower portion and split). What are other builders using for spacing? How close to the lower hinge should I go? Has anyone noticed any pillowing or cowl lift when using the 3.5" spacing? I received 19 flanges and locks in the RV1014 upper cowl kit I purchased. Seems like I have more then I'll need? Or am I missing something?
