dhmoose
I'm planning to order some fasteners from Skybolt but need some help to determine which kit is most appropriate for my situation. I've installed the hinge pins for the firewall sides and the horizontal pins for the upper and lower cowl halves. Since I've heard of problems with the upper and lower firewall hinge pins... Those are the ones I'd like to replace with the Skybolt fasteners. That said, do I order just the "upper firewall" kit? If so, what is to be done with the lower firewall area?
Little help would be appreciated.
Thanks.
Thanks.
