On the tailcone plans page 10-25, it shows a rivet layout. They depict the rivet size and type along the top of the side skins (triangles and squares). On the next page they show the aft top skin, no rivets are depicted along the forward and sides. It would seem that the sides of the top aft skin is to go under the top edges ( inside)of the side skins. This doesn't seem correct but following the rivet layout this is what I'm deducing? Otherwise they would show the rivets to use on along the 1032-L and -R longeron line on page 10-26, of the top skin.
Also the aft bottom skin F-1079 shows one rivet on the forward end on page 10-25. Both side skins show the bottom aft corner rivet implying the side skin is on top of the bottom, (which it has to be). F-1079 slides inside of the aft side skins, but the plan shows the forward center rivet to be on the F-1079 depicting it is on topof the bottom skin? This doesn't seem correct to me. Hopefully someone can make out my concerns and straighten me out.
Thanks Ron
Thanks Ron
