how did you guys do the dimpling/machine csinking. The bottom and top rear skins are .025, the sides are .032, do you dimple both of these then machine csink the longeron? if you dimple just the outside skin then machine the sandwiched skin you really enlarge the hole since the machine csink for a dimple is much deeper than that for a rivet. How should I do it?
