I remember in Jr. High, one of my friends cut a piece of his project too short. The shop instructor said "go get the board stretcher". So... I need a Skin stretcer for my tank skins ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Here's my issue. I've assembled the wing skeleton, per the plans. I've also assembled the Leading Edge and Tank assemblies (Clecoed only at this point). So I put the wing skins on the skeleton, everything lined up just fine. I then put the leading edge on, everything was fine there as well. Lastly, I put the Tank on (still cleco'ed only at this point). I put cleco's throug the tank skins into the main spar and, you guessed it... there was a problem (see photo).
Where the top wing skin and the tank skin meet on the main spar, I have 1/16" gap. The holes line up perfectly though. Is this a normal occurrance? I also have a small gap where the LE and Tank skins meet on the splice strip that joins them.
I'm not quite sure where to go from here... neither one appear to be anything more than a cosmetic issue. If this is "normal" then I'll press on, if not, I'd like to fix them before I rivet anything else on that wing. I went as far as taking measurments looking for twist in the wing, but it came up with only 1/32 difference between the inboard and outboard readings.
Thanks for your help,
Darrin "Dex"heimer
RV-9A - Wings (for 3 years :-( )
![Wing_Skin_Gap.jpg](/proxy.php?image=http%3A%2F%2Fwww.boxbar.net%2Fimages%2FWing_Skin_Gap.jpg&hash=ca424e6e9e68a05a2bde6ffb17280aa0)
![Wing_LE_Gap.jpg](/proxy.php?image=http%3A%2F%2Fwww.boxbar.net%2Fimages%2FWing_LE_Gap.jpg&hash=342c0678ac3d98508bb31646e4790104)
Darrin "Dex"heimer
