Hi Guys
I'm a newbie here. I have just started on my 8 and have never used these 12 inch drill bits before. So, in my infinite wisdom, I have cocked up! I think.
The plans called for me to use the long drill bit to drill thru HS810-1 and the HS404/405/FWD HS702 spar. Well, on my first hole, i drilled a bit skew. Not knowing exactly how to hold the condounded drill bit! So now, that rivet, which i havent riveted yet, sits a bit skew.
Do i just go ahead an rivet that rivet in skew, or order a whole new HS 810-1 reinforcing angle??
If i do rivet this rivet as is. Any advice as how to hit it. Do i hit the thing in line with the rivet shaft or parallel to the spar/reinformcing plate?
Regds
Regds
