claycookiemonster
These:
https://www.aircraftspruce.com/catalog/appages/eyeballfw2.php?clickkey=183193
Does this fitting split open so I size it for the portion of the cable which will rest inside once installed, or must the opening admit the largest portion of the cable?
If I must allow the largest portion of the cable to pass through, what is the best way to seal around the smaller diameter portion once it's installed?
