Gang,
I found that my mechanical fuel pump is leaking fuel from around the gaskets where it clamps together. It's irritating since I just replaced this pump a year and a half ago and it wasn't easy.
I also found that the o-ring for the inlet fuel fitting was bugered up. I replaced it with a dubious one that I found on my workbench to make sure that wasn't the source of the leak. I want to order the correct part but don't know what size it is.
The engine is an IO-360-A1B. The fitting adapts the straight threads on the pump to an AN-6 flair fitting for the hose from the firewall.
Anyone here know the o-ring size?
Thanks.
Thanks.
