humptybump
The title pretty much says it all.
Using the details from multiple threads here on VAF and elsewhere, I created a simple and robust essential bus that has a backup battery source which charges off the primary source when available.
The most asked questions are the values for the components. I build two of these: the first used a 2 ohm 20 watt resistor while the second used a 4.7 ohm resistor. I prefer the first but the second has less stress and is what I would build if I were to make a small batch of these with the surplus parts I have. (I have enough parts for 5 or 6 of these units). The Schottky diodes are rated at 30 amps (15 amps per leg).
The way I installed this is to have a 10 amp fuse (or breaker) on the input side for each of the main and backup feeds. The output goes directly to the essential bus.
