Oh, which silver to use?
Hey Fellas:
Good thread -- I'm looking to spray a C45 (to protect the aluminum, more than anything else), and getting that much silver wrong would not make me happy.
My plan:
Check out some paint chips, and pick the silver with the least amount of black in it (to get the lightest/brightest color). I used 1994 GM fleet silver on my 1st Rocket -- the one with silver and black on it, and it turned out pretty well indeed. I'm gonna look at that one 1st, and go from there. My preference is single stage (weight on that much surface area is considerable -- probably 300 lbs or so?), tho base/clear is striking, and easy enough on a smaller subject.
Remember,if you goof up (runs, sags, etc), you cannot sand out any metallics. Hire a good gun man before mixing up any final color coats.
Nuvite makes a good polishing system, and a std buffer can be used to polish the ship. I did a couple pieces of the Beech, and even tho the starting point included quite a bit of sfc corrsion, it went OK and the final product was actually acceptable. Starting with a newer RV would not take any more time than a paint job would, and would allow for a lighter ship...I just don't have the energy to polish an acre of 65 year old aluminum...
![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
especially when about 40% would be on the bottom.
Carry on!
Mark
