YankeeBravo
Member
Good day,
Trying to understand how to bond transparencies using Sikaflex 295UV. I read a 2019 Kitplanes article on the subject but could not understand why using both the 205 activator plus the 209D primer before applying the Sikaflex itself.
Attached is a screenshot of a webinar from a Sika senior product engineer clearly mentioning not to use activator on acrylic glass.
My conclusion are that only a thin layer of primer 209D should be used before applying Sikaflex 295UV.
Thanks in advance for any comments for or against this option...
