I have a question on the techniques used to install the plexiglass canopy to the steel frame using the Sika adhesives.
One is to glue the plexiglass onto the steel frame while the frame is mounted on the aircraft.
The other is to carefully layout where the steel frame is in relation to the plexiglass while on the aircraft. Then lay the plexiglass upside down on a carpet table and place the steel frame in it. Clamps are applied and then the adhesive.
Which way has most people used? Pros and cons?
