Shrink tube
Don Patrick
I have an easy questions. I'm soldering the wires to the BNC connectors for my capacitive tanks. Is it a problem to put some shrink tube over the soldered joint, and then cover it with proseal?
The soldered joint appears to be nice and strong, but I just want to make sure that it won't impact anything by adding the heat shrink tube.
DP
I cant see a problem with it. Although once the pro seal has set I think that the support the heat shrink will provide is insignificant.
