andoman
Referring to the oil pressure relief adjustment tower.
I’ve read there are short and long versions and that 3 or 7 adjustment washers can be used depending on length. A search of the parts manual has not answered my question. I only see the standard and externally adjustable versions.
Is it simply that the externally adjustable unit is the “long” version?
And where does the 3 or 7 washer limit come from? The Parts manual calls for washers “as needed.”
Thanks.
Thanks.
