rapid_ascent
As I start work on my fuse kit I'm trying to plan my interior painting. I've decided to go with Jetflex WR for the topcoat and the recommended two part primer. While I'm moving into new ground I think I want to upgrade my gun from my HF gun to a Devilbiss Startingline gun with the Dekups system. These guns are sold in several different configurations with different tip sizes: 1.3, 1.5 and 1.8.
I've read some of the threads on using Jetflex, but I need more specifics. The primer is solvent based and the top coat in my case will be water based.
So... My question is what is the best tip size to shoot each of these products. At this point I can buy whatever is most appropriate so I'd like some guidance from the brain trust on what they have used. Also can I use the same tip for primer and the top coat?
