I was puttering around the hangar and just happened to notice a slow drip from the fuel tank sump drain. Ran a few shots of fuel into the trusty fuel tester in hopes of flushing the trash from under the o-ring. It just got worse, so I retrieved a wrench, a spare drain valve, and a catch pan, then crawled up under the airplane to do the swap. I reached for the dripping valve......and discharged a fat blue lightning bolt about an 1/8" long directly to the wet brass.
It didn't light. No bandages and I still have an airplane.
No idea how I managed to build a static charge so quickly, but I did, and the lesson is clear. Discharge yourself by touching some metal part of the airplane before you reach for any fuel component....in particular valves dripping fuel.
