Hi Guys,
I?ve been keen to start building a kit aircraft for some time now and after MUCH reading and researching, I?m pretty much sold on an RV-10, just need to go for a ride in one to make 100% sure. I?m thinking the QB path for wings and fuselage to try and speed up the process (hopefully the quality of workmanship will be satisfactory!).
For the Australian based builders in the forums, did you (or will you) order the entire kit in one go, or one section at a time? Is there a significant shipping saving to be made by ordering it all at once? Storage space is an issue for me so I would prefer to order as required, however if it will be significantly more cost effective, I?ll get the lot at once.
Cheers
Matt
Cheers
Matt
