Electrogunner
Have read a couple articles about aircraft wiring and have come to the conclusion of use shielded wire on anything comm, data or audio related. Anything else can be non shielded ie, le nav postion lights,trim motors, flap motors,pitot heat, led interior lighting. I'm using led nav/ position lights so don't have any high volt power packs to give off EMI. All coax will be triple shielded ECS 311601 appears to be really good stuff and kept away from power circuits as much as possible. I am planning on bringing all grounds back to 1 or 2 locations, 1 behind baggage and 1 behind panel. Are my thoughts correct on these observations.
