Ok, please don't let this turn into a primer war.
If I decided to use Sherwin Williams P60 G2, is it best to scotchbrite the surface prior to application or would this remove the alclad?
If it removes the alclad, then you are removing the alclad, then rinsing (introducing moisture), then painting over it?
