Settings for Red line
dweyant
here is probably a dumb question...
I just got my panel powered up and I"m working on configuring things with the G3X.
I need to set green/yellow and red ranges for everything from amperage to manifold pressure to oil temp, etc.
How do I find the recommended values for all of these?
-Dan
Your engine manual should have most of that data. I've got a IO-360-M1B from Van's and the included Lycoming manual had all the parameters and limitations.
The alternator manual will have duty cycle limits for amperage
Dan,
Here is what I started with. Not sure it is what I have them set at now.
Van's has a pdf on their site that shows the ASI colored arc settings for the RV-9.
** Please use this with caution and only after you have verified each number.
